File naming queation using manual injection (Chemstation)
Posted: Sat Mar 25, 2023 6:06 am
Hi everyone:
I'm using a Agilent GC6890(Chemstation A.09.03) system. The autosampler was not working so I changed the method to manual injection mode.
My question is the file name(datafile name) can only be entered manually each injection or just follow the prefix/counter(e.g., sample0001, sample0002... ) in manual injection mode. Is it possible to name datafile by sequence setting under manual injection mode?
Thank you
Thank you
