File naming queation using manual injection (Chemstation)
Hi everyone:
I'm using a Agilent GC6890(Chemstation A.09.03) system. The autosampler was not working so I changed the method to manual injection mode.
My question is the file name(datafile name) can only be entered manually each injection or just follow the prefix/counter(e.g., sample0001, sample0002... ) in manual injection mode. Is it possible to name datafile by sequence setting under manual injection mode?
Thank you
I mean you can setup a sequence in the sequence table as usual and then in manual injection mode Chemstation will simply wait until you do the injection and trigger the start on the instrument at each sample. We sort of do this because we control the autosampler we have with a third-party program and our GC is set to manual injection mode.
In total there are 64 users online :: 0 registered, 0 hidden and 64 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 64 guests
