I am using chemstation C.01.10[287]. I have modified an existing custom report in report layout. When using the Report Preview and Review buttons, the layout is changed correctly. When I preview and print the report from Data Analysis the changes I made revert.
I have changed the name of the report template, double checked the file path, restarted offline and online, and restarted the computer. Data analysis still pulls the older version of the report.
Any other ideas on how to get the correct report to display/print?
Thank you
Edit: I figured it out. After saving the new template with a different name, I deleted the previous report. When I renamed the template to the previous name, the changes reverted. It must require a completely new file name to save I guess.
