Extracting a peak for UV/VIS Analysis
Posted: Mon Aug 15, 2022 2:58 pm
Does anyone know what is entailed in extracting a peak from a HPLC-UV chromatogram for UV-VIS analysis?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
https://www.chromforum.org/
Please give a step by step on how to do this with lets say a LC-UV chromatogram with 2 peaks.When working with PDA, you probably want to extract a wavelength chromatogram. If only one substance absorbs well on that particular wavelength, then you'll eventually have an extracted chromatogram with just one peak. But if other compounds also absorb at that wavelength, you'll still end up with multiple peaks.
1. Find the corresponding command for the chromatogram extraction in your software.Please give a step by step on how to do this with lets say a LC-UV chromatogram with 2 peaks.
