I'm trying to edit a cg-fid method in a Thermo Trace 1310 and in the oven configuration part I cannot find the "Post-run temperature" (which was in the original method we have been using 'til now and should be "literally" copied in the new Thermo).
Does anyone know how to access the Post-run configuration in Thermo?
Thank you
Laura
