On-column inlet injection
Posted: Wed Jun 17, 2009 8:03 pm
I had a cool on-column inlet installed on my GC/MS system. I'm using the same auto-injector as before, except a different syringe support assembly was required (equipped with a needle guide for the smaller 5uL syringe). This assembly refuses to make an injection. It either smashes the needle or just faults and aborts.
I have the correct size insert, syringe needle, and septum nut for my column size. Has anybody encountered this problem??
