How to get EIC chromatograms into final report?
Posted: Wed Sep 09, 2020 3:45 pm
6 month GC-MS newbie here. I'm using an Agilent 5975 MS with a 7890 GC on Masshunter software. Basically, I'm trying to get the EIC chromatograms into the quant software and eventually into the final reports.
I can export images of the EIC chromatograms in qual and then place them into the reports manually, but this is going to be very time-consuming once our throughput gets higher. As of now only the TIC can show up in the "Sample Chromatogram" graphic. I'm using the Report Builder 10.0 if that helps. Am I missing something obvious(hopefully)? Is it something with the data bindings maybe? I'm kinda blindly adjusting settings but if someone can speed up the process that would be much appreciated!
