I can export images of the EIC chromatograms in qual and then place them into the reports manually, but this is going to be very time-consuming once our throughput gets higher. As of now only the TIC can show up in the "Sample Chromatogram" graphic. I'm using the Report Builder 10.0 if that helps. Am I missing something obvious(hopefully)? Is it something with the data bindings maybe? I'm kinda blindly adjusting settings but if someone can speed up the process that would be much appreciated!
