Issues with LC-UV spectra Chromeleon
Posted: Tue Apr 14, 2020 9:16 am
by kate_m
hi everybody
is anybody familiar with chromeleon?
i have a sudden issue with my UV data where it shows literally everything so i cant identify any of my peaks - see image 1.
see image 2 for what my uv spectra used to look like for the same peak - it is a control sample from a different sequence.
I am unable to assign peaks using my spectral database either as he doesn't match to the peak he should. I am certain what this peak is and what he should match with because it is a spiked sample.
The spectra sampling points are blanked out if i right click > properties - see image 3.
Can anybody help?
kate
Re: Issues with LC-UV spectra Chromeleon
Posted: Thu Apr 23, 2020 5:08 pm
by pwm
Looks like the peak you want is at 211nm from the good spectrum? That appears to be missing from the bad one. Do you have any 2D chromatogram comparisons?
