Column thermostat?
Posted: Thu Mar 05, 2009 3:36 pm
by tnt_tx
Anyone know a US supplier for a stand-alone column thermostat (~5°C to ~80°C) that can be qualified and doesn't take up much space?
I'm using an Agilent 1100. Agilent's column thermostat compartments are ~3k - without a valve assembly! That amount of money isn't in the budget right now and a bit overkill for my needs anyway. I remember using a stand-alone thermostatted compartment at a previous employer with Shimadzu systems, but can't recall the brand (wasn't Shimadzu).
Thanks in advance,
t
Posted: Thu Mar 05, 2009 6:33 pm
by tom jupille
You can probably find what you need from any of the major consumables suppliers. Here's one that I know of:
http://www.analytical-sales.com/Heaters.html
Posted: Fri Mar 06, 2009 10:26 am
by Markus Laeubli, Metrohm
Posted: Fri Mar 06, 2009 2:53 pm
by Consumer Products Guy
We got one for better than free a few years ago from Grace Alltech, still in its package. It was less expensive to buy their conductivity detector and a column thermostat together than the conductivity detector only. Yes, you read that correctly.
thanks for the suggestions
Posted: Fri Mar 06, 2009 8:42 pm
by tnt_tx
Thank you all for your feedback. I've been looking into suggestions and have more info to track down.
If only I needed a conductivity detector
t
Column Thermostat
Posted: Fri May 08, 2009 8:39 pm
by ksm
I have big temperature issues with my ion chromatograph (Metrohm) , and I went on the hunt for a column heater/chiller. I discovered that Restek and Phenomenex have heater/chillers that work for both HPLC and ion chromatography. As a matter of fact, I am going to be trying out the Restek one for a week this summer with a loaner to make sure it will take care of the problem. Also, Sigma-Aldrich carries the Jetstream Plus Column Heater/Cooler. FYI, all three seem to be reasonably priced.
