Some methods I found are:
Chiralpak OD-H (4.6x250) 1 mL/min, 9:1 Hex:IPA, 12 min. (210 nm)
Crownpak (Daicel) 0.7 mL/min, pure water (pH2), 16 and 19 min. (254 nm)
After acetylation,
Chiralcel AD-H (4.6 x 250), 0.5mL/min, 9:1 Hex:IPA.
The columns I have: Chiracel OD, OJ and Chiralpak AD.
So far I only have luck after acetylation, with Chiralpak AD using the same method reported.
But be nice if no acetylation needed. So I have been playing around with my OD and AD columns but have no luck with separation. I also have no idea how the first method was done, because I was never able to get a nice flat baseline at 210 nm.
Any advise?
