Since the peaks I get are of similar width I havn´t played with time constants or integrator sampling rates for a long time, so memory is probably foggy. Now I seem to recall that setting the time constant too fast lowered mostly the peak hight, setting it too slow increased noise, making the peaks appear wider?
Setting the sampling rates too low also obliterates part of the peak, maybe I am confusing the influence of part of the two systems?
