I replaced the jet and the H2/air flows looked more stable. I however ended up with other issues, as the FID output was very high (~500000), which made me think that something was shorting. After an unsuccessful attempt at replacing the spring (which looked bent), I ended up calling Agilent for help and all is now well after an engineer visit.
Learning every day!
Thanks to all for the help.
