dichloromethane
dear all
i need specific packed column for analysis dichloromethane (methylene chloride)
thank you
ravi
any porous polymer packed column
any methyl silicone column with a heavy loading
any carbopack packed column especially if Carbowax coated
Often DCM has inhibitors, check the label of the bottle.
chloromethane and chloroform are obvious possible contaminants but look for other common solvents, especially acetone and 1-pentene.
Perform analysis at a low temperature but ramp to higher temperature for 'dissolved' contaminants.
best wishes,
In total there are 35 users online :: 0 registered, 0 hidden and 35 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 35 guests
