Varian 1200 GC-MSMS
I hope someone can give me an advice. My Ion source gets dirty very fast. I have to clean the ion volume almost every week and the ionblock every 3 weeks or so. We test pesticides and make a cleanup before we measure. The ionblock didnt look so yellow after 3 month before the problem began. The only thing i can think of is a leak so oxygen can come in. Im going to change the column and the fittings.
DId someone have the same problem ?
... The only thing i can think of is a leak so oxygen can come in. Im going to change the column and the fittings.
Before changing column and fittings execute test for leaks. You will get some information where the leak exist (provided it is a leak).
I already did that and there is no leak detektable. That's why i waited so long to finally do that. maybe the column is to old and starts leaking.
I know what happend now, the tiny plastic cap on the transferline was broken.
In total there are 44 users online :: 0 registered, 0 hidden and 44 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 44 guests
