FID response on HP 5890
Posted: Mon Feb 02, 2009 5:10 pm
Hello all,
Currently my lab is running a few HP 5890 series II+ GCs. This morning as I was religting our FIDs I noticed that one of them was not displaying a signal. This seemed strange to me as each of the detectors gave that satisfying "pop" sound confirming that there was combustion. Also, when a glass vial was held above each detector condensation appropriate to a lit FID appeared. Finally, as I opened ChemStation I noticed that there was no signal being tracked in my online signal window.
I am curious to know, what factors would influence this. Our FID card is set correctly. Next, I reset the column with new ferrules. One possibility that comes to mind while writing this is that the column stationary phase could be shot, clearly influencing the detector's abilities. Obviously a new column would be the easy fix in that case. Has anyone else experienced similar issues?
