Automatic timer 40 amps for hot plates
Posted: Mon Oct 21, 2019 3:04 am
by bdhedhy19
I cannot find high amps automatic timer for hot plate, that can be programmed to turn on or off at certain time. I found one at Home Depot and it worked for lamp but doesn’t work for hot plate. I don’t know the amps of hot plate. If anyone has any idea, please let me know
Thanks a bunch
Re: Automatic timer 40 amps for hot plates
Posted: Mon Oct 21, 2019 2:07 pm
by Consumer Products Guy
I cannot find high amps automatic timer for hot plate, that can be programmed to turn on or off at certain time. I found one at Home Depot and it worked for lamp but doesn’t work for hot plate. I don’t know the amps of hot plate. If anyone has any idea, please let me know. Thanks a bunch
Since your hot plate plugs into a standard receptacle, it pulls less than 15 amps.
So a timer like this will work, I use for my standalone ice machine.
https://www.homedepot.com/p/Defiant-15- ... /203677447
If your receptacle looks like this, then it's 20-amp
Posted: Tue Oct 22, 2019 7:14 pm
by James_Ball
40 amps would mean it is a 220/240Volt hotplate. Not sure I have seen any 220 volt timers at home depot or lowes. You might try Grainger, they deal with farm and industrial type products.
Edit,
Well I did find one at home depot
https://www.homedepot.com/p/Intermatic- ... /203557614
Is that something that might work?
Posted: Tue Nov 05, 2019 3:37 am
by bdhedhy19
I found one at Grainger Industrial as you suggested, exactly the one I was looking for!
Regards
