low pressure solvent chcek valve
Posted: Sun Oct 20, 2019 9:14 pm
by remesquaddie
Am looking for a solvent check valve to fit onto a teflon line [ 1/8 th inch ] that will prevent solvents from going back to the mobile phase bottle when priming a pump that sits low compared to the mobile phase container .
All help gratefully accepted.
Re: low pressure solvent chcek valve
Posted: Wed Oct 23, 2019 8:27 am
by ChristofferBR
Apparently something like this exists in standard online fitting style housings,
https://www.chromtech.com/inline-check-valves
though I must say, I would think any kind of flow restriction on solvent lines would be undesirable, especially with low hydraulic head.
Posted: Wed Oct 23, 2019 6:06 pm
by remesquaddie
Found a check valve that will do this admirably.
