Problem with liners Shimadzu
Posted: Thu Oct 10, 2019 7:46 am
I'm using a Shimadzu 2010 GC-System with an OCI wich runs with glas-liner in Split-Mode at a ZB5 Column. The Glas-Liner are filled with glas-wool. The problem is that the wool sliped down the liner and blocks the flow onto the column and the result is an unuable system. The Shimadzu-Service can't give me an answer why the wool slip down. Does anybody else have that problem with this liner? The Shimadzu Part.Nr. is P/N961-01481-02
