GC-HS reproducibility problems using the CTC
Posted: Tue Jan 27, 2009 7:28 pm
Let me start by saying I'm new at method development.
I am having problems obtaining reproducibile results on a GC 6890 with a CTC headspace sampler. I am injecting a standard solution containing TEA, methanol, ethanol, acrylonitrile, acetonitrile, toluene, pyridine, and 3-picoline diluted in buffer using a stabilwax column (30 x 0.32 x 0.5). When I analyzed my standard on the GC 6890 with a 7694 HS sampler my RSD values are <5%, but with the CTC they range from 2-30%.
Thanks.
GC parameters:
Oven: 55C hold for 4 min, 30C/min to 200C
Split ratio 5:1
Column Flow: 2.5mL/mim
HS parameters for 7694:
Vial pressure: 10psi
Oven/Loop/Transfer line temp: 85C/ 95C/ 110C
Vial Equil time: 10 min
Pressurization time: 0.2 min
Loop fill time: 0.15 min
Loop equil time: 0.05 min
HS parameters for the CTC:
Incubation temp: 85C
Syringe temp: 110C
Inj Speed: 1000 uL/s
Pre/Post inject delay: 0ms
all other at default parameters are set
Thanks.
GC parameters:
Split ratio 5:1
Syringe temp: 110C
