Triclosan Repeatability and reproducibility
Posted: Tue Jan 27, 2009 7:42 am
Hi to all,
I am trying to analyse triclosan for the related substances as per the USP monograph method. I have little bit doubts to carryout the test. The procedure says to prepare the test solution as follows:
Test Solution- Transfer about 2.0 g of Triclosan, accurately weighed, to a screw-capped centrifuge tube, add 5 mL of 2 N potassium hydroxide, and shake for 10 minutes to dissolve. Add 3 mL of n-hexane, shake for 10 minutes, and allow the phases to separate. Transfer the organic layer to a suitable container, add another 3 mL of n-hexane to the aqueous layer, shake for 10 minutes and allow the phases to separate. Transfer the organic layer to the previous extract, discard the aqueous layer, add 3 mL of 2 N potassium hydroxide to the combined organic layers, shake for 10 minutes, and allow the phases to separate. Transfer the organic layer to a suitable container, and evaporate with the aid of a stream of nitrogen to dryness. Dissolve the residue in 1.0 mL of methanol, and mix.
In the above said procedure how i can acheive repeatability and reproduciblity results and what type of apparatus can i use to dry the organic layer.
Please help if any body concern with the subject.
nageshwar
nageshwar
