Sulfur Species Analysis
Posted: Tue Oct 08, 2019 7:39 pm
by nizar84
Dear Friends,
Is there is any method or possibility to analyze sulfur species in Heavy Gasoil which has IBP-230 deg C and FBP of 570 Deg C. If you have any idea kindly share.
Nizar
Re: Sulfur Species Analysis
Posted: Wed Oct 09, 2019 7:33 am
by antonk
As far I known - in oil processing nobody cares about sulfur-containing components (individual content) but cares about total sulfur.
https://www.rigakuedxrf.com/petroleum.p ... gI9LPD_BwE
Posted: Wed Oct 09, 2019 9:28 pm
by James_Ball
I don't remember the method numbers but when I was in university and doing coal chemistry there was a test for Forms of Sulfur that was an ASTM method. It would determine Sulfates, Sulfites, Sulfides,Sulfur and Thiophenic Sulfur. But not individual organic compounds.
Posted: Thu Oct 10, 2019 4:04 pm
by AICMM
nizar84,
Probably your best hope is an SCD but that having been said, SCD is subject to HC interference. Since a gasoil is a blend it means you will have HC across the whole chromatogram. In that scenario, the other mechanism that would be helpful would be 2 dimensional since the sulfurs should elute slightly differently from the HC in the second dimension and the SCD would be less subject to interferences.
Probably not the answer you wanted - sorry
Best regards,
AICMM
