MassHunter Report Builder
Posted: Tue Oct 08, 2019 6:13 pm
by ScientiaPotentiaEst
Hey all,
I'm building custom reports in MassHunter for the EPA 525 GC-MS method I'm almost done developing, and I'm officially out of my depth with something. Specifically, I want the report to print out the Original and Final peaks and qualifiers, but to only do so when a manual integration has been performed for a given compound in a given sample. That is to say, I want this report to generate the following:
* A page of summary information for a given sample, including the TIC and a list of all analyte/QC concentrations and accuracy values
* A page with one or more sets of original/final peaks for each analyte in that sample which has been manually integrated
* The next sample summary page
* The next set of manual integrations
* Etc, etc...
Does anyone know the Data Bindings, filters, or other sorcery I need to perform in Report Builder to make that happen?
Re: MassHunter Report Builder
Posted: Wed Oct 09, 2019 8:03 pm
In case anyone is curious, I've got Agilent on this and hopefully will get a call back shortly about it from one of their programmer-type people. I'll update this with any information they give me when I get it.
Posted: Fri Nov 15, 2019 9:10 pm
by DrLincoln
I'm really interested to see what you can find on this. We have the exact same problem here and from what I can gather I don't even think this is possible since there is no "previous integration" value in the XML that I could find... but maybe there's some magic I haven't found yet.
That said, I also wouldn't put too much faith in Agilent's technical support on masshunter report developing. The last time I called them with something relatvely simple about developing a masshunter report (listing all qualifier ratios in the same table as the quantifier) they threw their hands up and said I should call one of their "consultants" for a fee to build it for me... I figured out the answer the next day.
Posted: Wed Jan 08, 2020 6:24 pm
by PickleRick
What was the fix? I'm a beginner with report builder and am trying to list qualifier MRM transition info (S/N, area, etc.) all in one row, but having no luck. I can get it to list both qualifiers' info, but it creates another row for that compound to do this.
Posted: Mon Mar 23, 2020 10:52 am
by Aivar080
It might be difficult. I would try to design Excel (it may be a slow of course) Template, and in this to use filter on column Manual Integration, yes/no ! if this is not empty, then the raw and graph are included else not included.
With best,
