Peptide sample introduction directly through solvent line
Posted: Sun Oct 06, 2019 7:48 pm
I read somewhere, on the topic of semiprep protein/peptide purification, that since at low eluent strenghts the analytes would more or less adsorb to the front of the column, it was possible to introduce samples by dunking a solvent line in analyte solution.
I was wondering if anyone has actual experience with that, as it sounds really dubious, and I can't really get my head around how you would even do it in practice, without either not getting all the analyte applied or getting huge amounts of air sucked into the system.
source: David Carr: A Guide to the Analysis and Purification of Proteins and Peptides by Reversed-Phase HPLC, p. 42, published by ACE columns
thanks in advance!
--Chris
thanks in advance!
--Chris
