Dear friends.
I have an old LSC2000 P&T that was not working due to a problem with the 6 port valve actuator´s motor. Now the motor is working, but the big problem is that some part(s) of the actuartor itself is(are) missing, they work by making to turn a shaft ( axis), this shaft in turn pivots the six port valve, I don´t know how these pieces are, please, if You have a picture of the actuator to see them I would really appreciate it.
thanks.
