Relative Retention Time
Hi!
Is it possible to calculate the Relative Retention Times of a chromatogram with Agilent ChemStation A.10.02?
Data export and excel calculation are inadequate.
There is a macro from the GC users that calculates relative retention times. It is not intuitive to use, but once it is set up it will work. You will need to know how to work with macros.
I believe I found it on the Agilent web site. You should also look in the ChemStation CD in the \ucl\ (user contributed library). It may be there as well.
Merlin K. L. Bicking, Ph.D.
ACCTA, Inc.
Thanks mbicking, I found it at last!
It's here:
https://www.chem.agilent.com/en-US/Supp ... 01282.aspx
