Check valve or active check valve?
Posted: Mon Jan 19, 2009 12:57 am
Hello,folks;
In some hplc system(e.g.,agilent 1200),check valve is repalced by active check valve;however still one ball check valve be retained as a outlet check valve.Check valve really bring lc pumps with most trouble of all components.So if it "can" be reduced, why not replace all?What's the difference between check valve and acitive check valve?
Best regards!
Best regards!
