Prefeerences for chromatography DOE software
Posted: Tue Jan 13, 2009 2:09 am
I am being asked to develop methods for more complicated mixture of analytes and know that I have to consider pH, solvent class, ionic strength, temperature, and column phase and interactions of all of these.
In a current (simple?) project on a neutral analyte in a cream, the matrix components (placebo) behave very differently than the analyte. The target analyte and degradants follow linear addititive effects for solvent and are reasonably predictable. The cream matrix has multiple peaks, with the major one wandering from the front of the chromatogram to the last eluting peak, depending on the mixture of solvents used and temperature, so I know at least the major placebo peak has at least a strong solvent class interaction between MeOH and ACN and probably a temperature component. I have four analytes of interest here and we tend to find mixtures that put the placebo peak on top of one of the four rather than between them.
This seems a good time to really use some DOE software and the company does not have any. Who has used DOE for chromatography and can recommend a user-friendly software package that will help? My next project is neutrals and basics with similar placebos, again at least four target compounds and again expecting interactions between multiple chromatographic parameters.
I leave this open to all suggestions and comments about strengths and weaknesses of anything anyone has used, including the built-in packages the vendors provide.
Thanks in advance for your opinions.
