DX-120 rear panel connectors
Posted: Tue Sep 03, 2019 9:56 pm
by Sweetwater
The DX-120 has a series of connector pins on the back panel in a vertical row for external control functions and signal output. Does anybody know what the mating connector would be or the name or manufacturer of that stye connector?
Sweetwater
Re: DX-120 rear panel connectors
Posted: Wed Sep 04, 2019 1:18 pm
by DR
https://www.thermofisher.com/document-c ... 1hbnVhbA==
There are 2, 3 and 5 pin connectors. I think the part numbers are in section B9 which is where diagrams of what they're all for are also located. I'd check with a Thermo rep before ordering to be certain that the part numbers are for the plugs.
Posted: Wed Sep 04, 2019 3:38 pm
by John Guajardo
Hi Sweetwater,
You can purchase the connectors using the following part numbers:
2-pin connector (921019 - CONN,1X2,PLUG,F,MSTBT)
3-pin connector (921186 - CONN,1X3POS,HDR,F,MSTB)
5-pin connector (921273 - CONN,1X5POS,F,SCR TERM)
