Plugged columns!!!
Posted: Sat Jan 10, 2009 1:53 am
Hi! If someone could answer why I have this problem with different kinds of columns when mobile phases contain sodium salts of butanesulfonic or heptanesulfonic acid. I have used a Bondclone 10µ C18 with sodium butanesulfonate 0.006M with 5% methanol and the pressure kept increasing as weeks went by until I could not use it anymore and the same is happening with a second column.
Something similar happened when I used a Spherisorb ODS-2 3µ with sodium heptanesulfonate 0.03M with 5% methanol.
In both cases I used a flow of 2.0 mL/min and I also cleaned the columns after each and every run, first with water and then with a high proportion of organic solvent (acetonitrile in most cases).
I have tried washing them with 100% organic solvent at a low flow but the problem remains... Please help me...!
Dominique.
Dominique.
