Recently regulatory authorities have been insisting in the analysis of potential genetoxic impurities in drug substances.The limit for these impurities is very low usually around 0.15µg/g of drug substance depending upon the daily dosage. Determination of impurities at such low level using HPLC/UV (of course some analysis can be done using LC-MS,but I have to carry out using HPLC/UV so that the analysis can be transfered to QC) is proving to be difficult if the drug substance as low solubility.Even if it is soluble it is overloading the column and causes its collapse. I request any of you who as experience in such analysis to give your suggestions. Thanking you,
Santosh Gandhi.
