Agilent 1100 Contact closure error
Posted: Tue Aug 27, 2019 6:52 pm
Hi all,
I've been tasked with maintaining a rather old agilent 1100 HPLC stack containing the following components:
Recently, the bin pump module began throwing all sorts of pressure errors that weren't easily solvable. We happened to have an identical spare bin pump unit, which I swapped in to the stack. Everything seems to be working now with the pump, but when I attempt to run methods through the Xcalibur software, the system hangs while waiting for contact closure and then crashes. If I manually program the LC using the gameboy control unit, everything seems to run fine. Is this possibly a control software issue?
I'm much more familiar with FPLC systems than HPLC, so I'm a bit stick with how best to diagnose this.
- Degasser
- Bin pump
- Autosampler
- VWD
