How to run chromeleon on a network?
Posted: Wed Jan 07, 2009 8:51 am
What I have, is a IC system and a PC which I use to start the server and the client (chromeleon 6.50).
What I need, is to be able to run an other session of the client from an other PC on the network, so that 2 persons can work at the same time.
here is the Licenses:
Is it possible to do what i need with the licenses I have, or do I need others. If it is the case, which one(s) ?
Thanks for your replys and sorry for my very bad english :/
