Uhplc leaks with MBTE as eluens
Posted: Thu Aug 22, 2019 1:13 pm
by piverap
For the analysis of carotenoids the C30 column is often used and MBTE is used as eluent. I also want to use this method on our hplc's (Thermo Accela and Shimadzu Nexera).
In both systems, however, the pump will leak at a high concentration of MBTE (> 80%). The pump heads have been cleaned and the seals replaced, but the problem has not been solved.
If another eluent is used, there is no problem.
Who knows how this problem can be solved.
Re: Uhplc leaks with MBTE as eluens
Posted: Fri Aug 23, 2019 12:26 am
by tom jupille
You would have to check with the vendor(s) to find out what alternative seal materials are available.
