Peaks
Posted: Mon Jan 05, 2009 4:32 pm
I am using the Dionex IC equipment and i am relatively inexperienced on it. I have run some water samples looking for anions such as nitrates, phosphates, chlorides, and sulfates. I end up with unknowns in my results. Is it possible to have two peaks for the same anion in my results? Or is it interference from some other source?
