How to fix air leak coming from gc back inlet?
Posted: Wed Aug 14, 2019 8:35 pm
I am having trouble with getting the air/water check to pass on GC-MS.
I was able to determine that the issue is coming from the back inlet by plugging the inlet side of the column and also testing out the air and water check readings when connected to the front inlet.
So far I have tried , changing septum, liner, o-ring, gold seal but I am still getting a relatively high N2 reading.
For reference this is what my air and water check looks like:
Water: 3.01%
Nitrogen: 21.06%
Oxygen: 6.39%
Carbon dioxide: 0.29%
The N2 readings usually fluctuates between 12 and 21%.
Any more steps I should take to correct the back inlet? I am using a split/splitless inlet connected to a headspace sampler.
GC:7890B
MS:5977B
HS:7697A
Water: 3.01%
Nitrogen: 21.06%
Oxygen: 6.39%
GC:7890B
MS:5977B
HS:7697A
