Dilution from stock solution - wrong results
Posted: Fri Aug 02, 2019 2:15 pm
I was recently asked to prepare standards of different concentration through dilution from the stock solution to construct calibration curves that will be used for quantitation of my samples.
I successfully prepared stock solution of the right concentration. However, after dilution of stock solution to lower concentrations, such as from 5000 ppb to 500, 300, 200, 100, and 10 ppb, I was unable to get the correct responses/concentrations after being analyzed using GC for my standards of lower concentrations.
What problems that I may have that leads to these inaccuracies?
Thanks!
Thanks!
