paper chromatography.
Posted: Mon Dec 22, 2008 6:39 am
Hello. I'm a student and we currently are doing a project for our science class and we need your help.
We selected this project: paper chromatography. However, we have failed during our first and second trials. We are doing this so that we could identify the dyes that are present in a candy, locally and internationally manufactured. Well, we have based our experiment on an article we found on the internet. We followed it exactly the way it was elaborated, but we still failed. This is what we did:
1. We placed the candies in a test tube and filled it with vinegar so that the dyes from the candies would transfer to the vinegar.
2. After the dyes have been extracted, we dipped an undyed wool yarn into the vinegar with the extracted dyes, then waited.
3. The dyes then transferred the the undyed wool yarn. After, we placed the yarn into another test tube with ammonia solution, then we waited. After some time, the yarns became white, like its natural color before dipping it into the vinegar with the extracted dyes.
4. We heated the test tubes with the ammonia solutions and the extracted dyes, making the solution concentrated with the dyes alone and the ammonia solution evaporate.
* in this step, the ammonia solution didn't evaporate, and the result
didn't turn out to be the way it should be.
5. When we were about to do the "spotting" part of the experiment, we weren't able to 'spot' because when we were to place the candy dyes on the chromatography paper, we weren't able to see colors. It was only like water, colorless. Despite having gotten it from the test tubes which contained the extracted dyes from the candies.
Some of the things we thought we did wrong that made our experiment a failure are these (maybe it could help!
- we didn't really heat it directly above a bunsen burner.
- we didn't use a chromatography paper, which was supposed to be used. We used a filter paper instead, which we thought would yield the same and exact results as a chromatography paper would.
****How could we also identify the exact commercial dyes that were used? Like the colors with numbers (e.g. Red 10, Blue 4). We really need to find out the answer for this. Thank you very much.
THANK YOU VERY MUCH!
