Range calibration curve EPA 8270D
Posted: Sun Dec 21, 2008 4:47 pm
On the one I have a little curiosity, I would like to know what the range that you used to calibrate the metdo EPA 8270D for PAH?
because I build from 0.1 ppm to 8 ppm and add the internal standard to 4 ppm.
This is because I have an abundance of the standard of 1 million!
Thank you
Buon Natale
Thank you
Buon Natale
