10E8 column bleed and bad tunes.
Posted: Thu Jul 25, 2019 6:05 pm
Hi all. I am running an Agilent 7200A model GC-QTOF with a DB-23 column installed. Getting bad tune results, and when I run samples or blanks, there is a massive column bleed signal at m/z 216,313,366 (the worst but not only). The DB-23 has been conditioned. Its operating range is 40-250, and my program is ramped 40-230 C. The QTOF had preventative maintenance, including source cleaning, last week. The tune could be an unrelated issue.
Any thoughts? Can post screenshots. Let me know what you want to see. Thanks!
