ion chromatography results and unknowns
Posted: Wed Dec 17, 2008 5:41 am
I am using the dionex IC machine and I am having problems determining the identity peaks in my results. I have established a series of linear equations based on the calibration results. I was told I would have to use the correct concentration and plug those values(peak areas) in order to compare with the unknown values. The identity of unknown would then be determined. I have calculated linear equations along with the r^2 values. Am I doing the right thing?
