problem using UV detector
Posted: Fri Dec 12, 2008 5:06 pm
I'm trying to use a Waters 2487 UV detector with our LC-MS system (UV set up for the first time). It's connected to Waters 2695 via IEEE488 and controlled by Masslynx 3.5. I can control the UV from the inlet editor, e.g. turning lamp on and off, changing wave length...When acquiring data from MassLynx sample list, it seems normal. It will draw the sample and run it for the time specified. However, when I viewed analog output, it only shows a flat line. After some troubleshooting, I found on the display panel of the UV detector, it shows the symbol of local mode.
Any idea why it shows local mode, even though it's controllable by software? How to fix it and get output signal correctly in masslynx?
Thanks!
Thanks!
