Hi Chris,
Many of our customers use UPS battery backups to protect their HPLC systems. Power problems are quite common and most people call up after they've had some sort of disturbance to try and prevent it from ruining the equipment.
Normal surge suppressors are pretty useless and offer little protection against power spikes, brownouts, and surges.
Home use surge suppressors are exactly that, they're meant for non sensitive equipment that can tolerate disturbances.
Most people don't use UPSs to get a long runtime but rather use them to ensure they get clean power to their machines and have enough runtime to shut down whatever they're doing safely.
I know that there is some sensitive testing equipment that does not like to be abruptly shut down and leads to loss of data and a very long restart time.
Also, UPSs are used as a line filter between a generator and the appliance to ensure that the appliance constantly received clean power. Some generators output dirty power as well as take more than a few seconds to kick in. The UPS will provide power during that time to ensure a safe transition.
Most good UPSs offer AVR boost and AVR drop to handle power increases and power drops. They can compensate for low power input and output a proper voltage consistently.
If you start shopping around for a good UPS, make sure you get something that offers AVR Boost Drop, power filtering, surge protection and outputs a sine wave. Anything that doesn't offer that, should be disqualified from the get go.
If you have any questions about battery backups, I would be more than happy to answer.
Yours truly,
Tony
We have had some problems with power supplies over the past few months and wanted to know of the use of UPS backup power systems is feasible for HPLC systems and if anyone has any experience of this.
