Peak Splitting
Posted: Wed Dec 03, 2008 4:16 pm
Iam in the process of developing a HPLC method for monitoring the reaction in the synthesis of a cephalosporin (Intermediate stage). when the product is isolated and injected into the hplc system I get a single peak (say RT@7mins), the solid dissolves in buffer. But when I add a little amount of solvent and then makeup with buffer i observe two peaks well seperated (one @RT 7.min and other @RT 2.0min). the uv spectra of two peaks are same.I want to know what effect will solvent have on the structure of molecule to be seperated.
Thanking you,
Santosh Gandhi
Thanking you,
Santosh Gandhi
