What Column size should be used in Agilent 5975 MSD
Posted: Fri May 31, 2019 10:39 am
Hello:
In a Agilent 5972 GC coupled with a Agilent 5975 MSD with Diffusion pump we have been using for a long time a column DB-5MS 60 meter column with 0.25mm ID and 0.25um film thickness. I have read in the manual that the column lenght should be 30 meter. The question is if using a column of 60 meter would be a problem, because we have a very large noise in the column and I thought that this is because of our samples, but I am thinking if the
lenght of the column could have an effect in it, because the pump system, perhaps is not doing the best vacuum. We don't have a vacuum gauge to check the vacuum in the Analyzer. Also other question is if we use a 0.5 film thickness, would it better the problem of my samples?. Our samples in this case come from essential oils and this samples let a large amount of dirty in the liner and in the split outlet. This is a fragance industry and we check fragances from many types. I think that this samples have many components that charge the column but if we have a thicker film then the column can handle in better form this samples. What do you think?
Other question is if it would be better to use headspace in this samples? Waht we want to analyze is the fragance and this are volatiles, I think that this can be extracted with headspace and so we can solve the problem of the dirty samples, but I understand that not all the fragances can be extracted with headspace. What do you think?
Thank you!!
Thank you!!
