Droplets forming on corona needle (ESCI+ source) [LCMS]
Posted: Wed May 29, 2019 2:09 pm
The primary user of our Waters UPLC Xevo TQD was let go a while back and we have been sort of teaching ourselves how to use it. We have an ESCI+ source (ES+/- and apci +/-). We don't typically use APCI and thus don't use the corona needle. However I don't think forming droplets on it are intended and it probably indicates too much fluid is being discharged from the ESI needle. We run at 0.4 ml per minute with 10% acetonitrile to 90% acetonitrile with 0.1% formic acid. MS parameters are as follows:
Desolvation temp: 350 C
Source temp: 150 C
Desolvation gas flow: 650 L/hr
Cone gas flow: 20 L/hr
I'd prefer not to decrease flow rate as that would increase our run times. Would increasing cone or desolvation gas flow help nebulize the droplets better?
Thanks for any help.
Source temp: 150 C
