Please, Now I have writing the project for poc doc.....my main idea is a analysis the endocrine disrupting chemicals....My question...Is possible to use QuECHERS method for then compounds ? Or my ideia is a sweet dream ..
I'd write the proposal suggesting Quechers as a possibility for quick analysis, but try not to lock yourself into using it. It's a broad range extraction and could prove itself reliable for 70% of the compounds you're interested in but a total wash for others. Also due to the small amount of cleanup typically used matrix effects can create problems for broad range detectors (ECD,FID,AED)
Another problem with Quechers is determining which modifications will best suite your needs, the original method has been heavily modified by various groups to better optimize it for their needs.
