Help Building a Post Column Reaction
Posted: Wed Nov 26, 2008 9:13 pm
Our lab is new to HPLC and just recently acquired a Waters Breeze system with fluorescence detector. I need to build a post column reaction setup from scratch using o-phthalaldehyde. I know from the literature that it's a fast reaction and that one can build a reaction coil by knitting PTFE tubing. What I would like advice on is the hands-on practical aspects of stringing the reagent delivery pump/line and reaction coil into the post-column flow.
Since I do not have much experience with HPLC plumbing/connections, I'm afraid of screwing up our existing tubing or purchasing the wrong fittings. Starting from the output end of the column, SS tubing leads from the column and feeds directly into the detector (with no external fitting). I need to tap into that line with a mixing T of some kind (to introduce the reagent) and the reaction coil before the detector. I would like to be able to add and remove the post-column setup easily, which leads me to believe (from what little I know) that some kind of handtight connectors are preferable with a union to close the line when the reactor is removed. Can anyone offer any practical advice on what fittings to purchase, cutting the existing line w/o introducing potential problems down the road (cut the SS tubing near the detector or near the column?), what fittings/connections can be used to join the teflon tubing of the coil to everything else, what kind of mixing T to get, etc?? Any help would be GREATLY appreciated! Thanks!!
