sciex ion source o-ring
I am having sensitivity issues with one of my Sciex 3200 LCMS instruments. Upon inspection I notice that one of the o-rings is missing where the ion source meets the mass spec and that an audible hissing sound is heard from the gas leakage in the ion source.
Is the missing o-ring a potential cause of the decreased sensitivity?
Yes,
If you are leaking gas there then you are loosing flow to either the turbo heaters or the flow around the capillary, so you will not be evaporating your effluent properly.
I think if necessary the o-ring is the same size as the inlet liner o-ring on Agilent GC Split/Splitless injection ports.
In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Most users ever online was 599 on Tue Sep 18, 2018 9:27 am
Users browsing this forum: No registered users and 15 guests
Subscribe to our eNewsletter with daily, weekly or monthly updates: Food, Environmental, (Bio)Pharmaceutical, Bioclinical, Liquid Chromatography, Gas Chromatography and Mass Spectrometry.
