In search of software/hardware to update older system
Posted: Sat Nov 22, 2008 10:10 pm
We have some older HPLC equipment in our laboratory (we are an academic research group). One system has the following components:
SSI 222C pump
SSI 232C gradient
Shimadzu RF-10AXL fluorescence detector
The other system has the following components:
Shimadzu RF-551 spectrofluorometric detector
Shimadzu SPD-5AV UV-Visibile detector
HP Series 1050 pump
We are looking for a system that can accomodate this instrumentation for use with Windows XP, Vista, or MacOS X (Windows preferred), along the lines of eDaq PowerChrom system (software + box to drive instrument): http://www.edaq.com/powerchromsystems.html. Are there similar systems available? Which is the best? The most cost effective?
Recommendations are appreciated.
Aaron
SSI 222C pump
SSI 232C gradient
HP Series 1050 pump
Aaron
